Date:    2-9-2004
Number of Hours:    6.00
Brief Description:    eng installation
Installed the motor mount on fusalage and motor mounts on engine. Set engine on motor mount and installed hardware for fit. Rubber mounts and brackets are compete and torqued to spec. Built the starter recess box for the firewall and did intitial fit. Drilled the seat belt holes in the fusalage mount points
