Date:    3-7-2005
Number of Hours:    3.75
Brief Description:    Finishing the HS
I rivitedthe rear spar to the skins. I riveted the inboard and outboard ris to the spar. I used blind rivet on the 6 Pars that couldnt be bucked. I assemble the hinge bracket bearing and installed. My first mistake of the project happened. I set the torque wrench wrong and striped one of the bolts out. Ill have to order another bolt.
