12-29-2006 |
0.50 |
Spar Angle Center Holes and Angle Double Check |
Dimpled the inboard-most holes on the front spar and c'sunk the matching holes in the spar angles. Took me about ten minutes of brain bending to make sure I had the dimples and c'sinks on the correct side of the parts. I think they're correct. Just to make sure, I decided to assemble the front spar as best as I could for now and double check the spar angle bends. They look pretty good. |
