Date:    12-3-2006
Number of Hours:    1.00
Brief Description:    Elevator Hinge Brackets
Clecoed and drilled all of the elevator hinge brackets on the rear horizontal stabilizer spar. Wasn't paying attention and didn't notice that the VA-146 bearing already had a radial hole pattern in it and accidentally drilled a second set of holes. I was asking myself the entire time I was drilling how I should make sure the bearing is centered in the brackets. Now I know. Dropped an email to Vans to see if this is OK. Awaiting their reply.
