1-11-2014 |
0.25 |
Tail - XNS-T06-09L and -09R - Measure |
Plans: XNS-T06 The plans indicate that this part should be made from 2x2 inch 60601 aluminium extrusion. However, this appears to be a typo based on the actual dimensions of the parts on the plans. The plans have a correction where the part XNS-T06-08 was previously marked to be made from 1.5x1.5 inch 60601 extrusion. This has been corrected to 2x2. The XNS-T06-09 parts are marked to be made from 2x2 inch. I believe that originally the draftsperson accidently swapped these and only updated the XNS-T06-08 part to be correct. The parts are also mixed up on the packing list. Based on the dimensions on the plans, it would make sense if XNS-T06-09 L and R are made from 1.5x1.5 inch extrusion and XNS-T06-08 is made from the 2x2 inch extrusion. In any vent, I used my incra rulers and blue Sharpie to mark the 1.5 x 1.5 inch extursion for the general shape of XNS-T06-09L and XNS-T06-09R as shown on the plans. |
