12-22-2009 |
2.80 |
Exhaust Test Fit and Elecrtrical |
Attach exhaust system to engine for test fit. Dressed and secured all engine ignition wires. Created a ground terminal block for central ground point. Secured all ignition wires. Wire all sender probes to RADC unit except for oil pressure sender which reqquires a resistive type (ordered fron Lockwood). Applied wire loom. Tested starter motor by removing plugs and actuating it. |
