Date:    11-30-2009
Number of Hours:    2.20
Brief Description:    Throttle and Choke
Revise location of choke cables as they pass through muffler mounting and set to corrrect length. Fabricater 3/8" nylon spacer for choke handle to give maximum throw on actuation.
On throttle cable, cut to correct length and swage end onto 1/16" bushing, secured with 2 swage compression fittings. Adjust idle position set screws on both carburetors. Set final length of cable with cable adjuster.
Locate position of egt sender probe on exhaust pipes.
Tighten clamps on oil hoses.
