10-24-2009 |
1.30 |
Fuel Control Cables |
Throttle Fabricate mounting bracket for throttle cable splitter out of 3/4" x 1/16" Al angle stock approx. 3" long. Drill mounting holes and bolt to engine block. Secure splitter with 4" nylon cable ties. Choke Fabricate mounting bracket for choke cable splitter from 3/4" x 1/16"Al angle stocck approx. 4" long and rivet to airframe on vertical support tubeon right side of fire wall with 1/8" rivets. Secure splitter with nylon cable ties. Secure choke handle mounting bracket upper right fuselage support tube attach handle with nylon nut supplied with choke. |
