Date:    12-4-2008
Number of Hours:    1.00
Brief Description:    Rotate redrive to upper position
Return engine, Serial No. 101273, to HPower, Inc. dba Flightstar, Inc., 91 Rte. 169, South Woodstock, CT 06267, to have B redrive rotated around crankshaft so that propellor output shaft is at the top position. Gearbox cover B and Reduction B gaskets replaced and redrive bolts torqued down to factory specs.
