Date:    10-7-2009
Number of Hours:    4.10
Brief Description:    Comm. Radio
Wire the comm./radio harness and solder to 15-pin connector supplied with FlightLine radio. Apply shrink tubing to each pin and test and assemble connector. Attach wires from harness to avionic terminal block behind panel on left side of cockpit. Connect GPS power plug and PTT switch to terminal block.
See wiring legend for wire specs, colors and numbers.
