Date:    9-10-2009
Number of Hours:    3.30
Brief Description:    Right Wing Lower Battens
Fabricate and trim lower wing battens and insert into wing pockets and snap into place as with left wing.
Install wing-tip position and strobe lights as per Kuntzleman instructions.
Re attach right aileron and melt 1/4" holes in cover for leading aand trailing edge strut brackets.Mount sturt bracket and aileron pulley assembly on inside of leading edge and secure with 1/4" bolts, steel washers and nylon locknuts. Mount aft strut bracket in similar fashion.
