Date:    7-29-2009
Number of Hours:    2.60
Brief Description:    Tires and Brakes
Check right main tire inner tube for leaks, repack bearings and remount wheel.
Install hydraulic brke control and master cylinder on forward control stick. Attach 3/16" OD nylon brake line to master cylinder with 3/16" compression fittings and run line aft to main gear mounting yoke. Secure to under belly with LG-23 cable clamps riveted with 3/16" HM-16 rivets to fuselage cross bars. Run brake lines inside main gear streamlined fairings to disc brake units on main wheels (L&R) and secure with compression fittings. Using HP-131 "T" compression union, secure line from master cylinder to lines for both wheels. Secure all lines in place with nylon cable ties.
