6-5-2009 |
1.10 |
Elevator push rod |
Shorten HC-132A elevator push rod so total length is abour 12-1/2". Drill out as shown in Dwg. 10A and secure threaded insert HS-23 with 1/8" solid rivets. Secure forked end of push rod to elevator bellcrank with AN3-6 drilled bolt, steel washer, castle nut and cotter pin. Adjust ball bearing end of elevator push rod to fit to elevator horn and bolt to bellcrank with AN3-7 drilled bolt, steel washer, castle nut and lock washer. |
