Date:    1-20-2008
Number of Hours:    4.00
Brief Description:    Fitting the empennage
The plans say you should use a 3/16 drill bit as a spacer under the aft spar but I found I needed to increase this by 1/32 to get the forward and aft tooling holes alligned with the rear deck.
