Date:    5-16-2007
Number of Hours:    1.00
Brief Description:    Cowl
Because the cowl halves are slightly over size and require trimming, I measured the maximum depth of the firewall and fixed the back of the cowl to a board at that measurement allowing the two halves to overlap. Clamping and triming the front to get the correct diameter behind the spiner was then straight forward.
