Date:    12-8-2007
Number of Hours:    5.70
Brief Description:    bell crank & ribs
Finished filing shape fcor bell crank mount. made a 16.5 MM spacer positioned & drilled & clecoed.
drilled & rivited tip to spar also cut out "L" angle for wing tip drilled & clecoed into position.
deburred lightening holes in all 9 rear ribs.
started cutting "L" angle supports for walk way for ribs 1 thru 3.
