Date:    9-6-2011
Number of Hours:    1.75
Brief Description:    Riveted HS-707 rib on Left & Right HS
I riveted the front HS-707 ribs on both horizontal stabilizers today. I had a couple of rivets get away from me on the bottom of the left HS and then ended up having to use a #30 bit and some oops rivets to rectify the situation. Go to my mistakes category to see what I did. The right side went much better without any mistakes. Now I just need to set a boat load of rivets and the horizontal stabilizer will be finished.
