Date:    2-20-2011
Number of Hours:    3.50
Brief Description:    Started Rear Spar Assembly
Since I am waiting for primer on the vertical stabilizer I decided to start on the rear spar assembly. First I needed to break the edges of the HS-609PP reinforcement bars so they would lay flush with the HS-603PP spar channels. I used scotch brite wheels on both the die and bench grinders to break the edges and smooth and polish the reinforcement bars. I ended up just using the bench grinder scotch brite medium and fine wheels because the die grinder made my compressor work double duty. Afterward, I final drilled the reinforcement bars to the rear spar with a #30 drill bit.
