Date:    9-6-2011
Number of Hours:    0.00
Brief Description:    Used Oops Rivets on Bottom Left HS-707 Rib
I had to drill out a couple of bad rivets on the bottom of the left HS-707 rib. Ended up enlarging the holes so I just drilled them out with a #30 drill bit and used a couple of oops rivets instead. It ended up looking very good.
