10-19-2011 |
4.50 |
Dimple and prepare fuselage for join |
First I drilled the package tray for the air conditioning unit to the longerons. Then I un-clecoed everything and split the fuselage. With the fuselage split, I marked and drilled the openings for the air conditioning hoses and the static line through the bulkhead. Then I dimpled all the skins and the bulkhead, trimming in a couple of places where the bulkhead met interference. Once everyhting was dimpled, I assembled the bulkehad and riveted it together. Then I rejoined the fuselage and clecoed it all together. Rivet count: 26 Total: 14326 - Plus 549 done at Van's |
