Date:    8-19-2011
Number of Hours:    5.00
Brief Description:    Assembled right side structure
Removed all the right side structure parts not already riveted to the fuselage. Deburred everything and countersunk the parts remaining on the fuselage. Deburred the forward channels and riveted them to the fuselage and then countersunk the #40 holes for the skins. Deburred and dimpled the rest of the structure before riveting the parts back on Used the shop vac to clean up all the chips and dust in the fuselage in preparation for dimpling the right side skins and clecoing them to the fuselage. If you notice how dark the later pictures are, it's because I had to close the hangar door when a huge thunderstorm inundated the airport with sleet.
Rivet count: 52 Total: 11966 - Plus 549 done at Van's
