9-26-2009 |
0.50 |
Replaced backup altimeter, switch lamp |
Replaced the old UMA backup altimeter with a two-hand, 20' sensitive altimeter from West. Also replaced the burnt-out lamp in the boost pump switch with an LED replacement that is much brighter than the other lamps. I'll keep the other switches as-is until/if the lamps fail. |
