10-16-2016 |
1.80 |
Complete Oil Hose Install |
Could not have accomplished tasks tonight without Denise's help. With oil hoses loosely connected to oil cooler, noticed that the VA213 oil supply hose from the oil tank rubbed against the spring clamp tangs on the lower left water hose off of the water pump. Loosened the clamp and hose at the forward end, then attempted to turn the other clamp but it was too tight to get pliers in that area. Eventually used multiple 3/8" extensions and a hammer and tapped the clamp to the top side of the water hose until the tangs cleared the oil supply hose. Installed and removed the bottom cowl several times and then tightened the oil hoses to the oil cooler. It is a challenge to get the oil cooler slots lined up with the cowl guides but it can be done with two people - one to poosition the bottom cowl and one to work from the right side of the engine and move oil cooler so it aligns with the cowl guides and bolts can be installed. Both hoses from the oil cooler have adequate clearance from the cowl, muffler, muffler springs, and water hose clamp. Added red RTV to specified locations and tie-wrapped hoses together behind the engine. (step 5) PAGE 49-17 AND 49-18 ARE COMPLETE |
