9-1-2016 |
1.70 |
Mark and Install Hinges |
Page 38-03 Beveled eyelets along curved portion of upper cowl hinges. (step 8) PAGE 38-03 IS COMPLETE Page 38-04 Fabricated mid cowl hinges and marked hole locations. (step 1) Marked hole locations in remaining hinges. Originally spaced holes at 1 1/8 inches as done for the mid cowl hinges but realized all other hinges are spaced at 1 inch per figure 2. Remarked per figure 2. (step 2) Installed upper cowl hinges, mid cowl hinges, and lower cowl hinges. Pins were especially tight for upper cowl hinges but got easier after being cycled in and out a few times. Did not see any obvious areas that needed to be fluted but did lightly bend by hand in a few areas. May have to readdress fluting once fitting the cowls. (steps 3 through 5) PAGE 38-04 IS COMPLETE |
