7-2-2016 |
1.10 |
Control Module Miscellaneous |
Page 42M-04 Machine countersunk attach screw holes for center panel. (step 1). Also, drilled 1/2" autopilot disconnect switch hole. Page 42M-05 Drilled 1/4" hole in center panel for dimmer. (step 3) Page 42M-08 Not sure why this page is here since the steps were previously accomplished in Section 42C. Machine countersink left instrument panel and install ignition & start panel. (steps 1 and 2). PAGE 42M-08 IS COMPLETE Page 42M-09 Connected ignition harness between the AV-5000A control module and the ignition & start panel. (step 1). PAGE 42M-09 IS COMPLETE |
