5-21-2016 |
2.40 |
Completed Bearing Bracket Mod (SB 14-12-06) |
Cut bearing bracket angles (step 6). Scuffed angles and bracket with Scotch Brite pad and clean with Acetone, then primed. Riveted bearing bracket angles to bearing bracket (step 7). Clecoed bearing bracket assembly in place (step 8). Riveted bearing bracket assembly to bulkhead and baggage ribs (step 9). Remaining steps NA for the Service Bulletin but will be accomplished when reassembling as part of mouse damage repair. THIS SERVICE BULLETIN IS COMPLETE |
