Date:    1-12-2013
Number of Hours:    4.20
Brief Description:    Removed Landing Gear & Rivets (SB 12-11-09)
Step 13
Removed both main landing gear.
Step 14
NA. Wing Root Seal not installed.
Step 15
Marked fuselage skins and removed rivets. Carefully drilled heads until they popped off, then punched remaining portion of rivets through skin.
Steps 16 and 17
NA. Aircraft not painted.
Step 18
Removed rivets and removed F-1204T-L & -R skin stiffeners. Used a 90-degree drill and drilled out rivet heads from above and then punched out remaining portion of rivets.
Step 19
NA. No skin damage as expected.
