Date:    1-11-2013
Number of Hours:    3.00
Brief Description:    Started Center Section Mod (SB 12-11-09)
Steps 1 through 7
Since the aircraft is still being built, these steps were not applicable because the following items are not installed: cowling, seat cushions, wings, inspection covers, battery, F-1205G ELT bracket, and fuel tank.
Step 8
With Michael's help, used new maintenance stands and raised aircraft off of the ground. Positioned stands at locations specified on page 1-18 of the Maintenance Manual.
Step 9
Not applicable since brake fluid not installed yet.
Step 10
Disconnected the F-1289D caliper brake lines from outboard sides of U-1203 inboard main gear attach brackets. This step calls out U-1302 which appears to be an error and should be U-1203.
Step 11
Removed two outboard cushion clamps securing F-1204Y wire run conduit.
Step 12
Marked and drilled 3/8" holes in F-1276 bottom skin on both sides of the fuselage.
