8-12-2016 |
1.00 |
Install Fuel Tank |
Installed fuel tank and secured forward end with frangible bolts (BOLT-00002). Torqued to 30 inch-pounds and torque striped. Temporarily installed AN4-6A bolt at aft attach angle - need to order AN4-4A bolt for final install. Attached and tightened fuel line and fuel return line at bottom of tank. Hand-tightened B-nuts then tightened an additional quarter turn. (step 1 - partial) Hardware references are on page 37-07 (R4). Installed fuel sender wire to fuel sender. (step 3). UPDATE 9-16-16 Finally ordered AN4-4A bolt. Removed AN4-6A bolt from aft fuel tank attach point, installed AN4-4A bolt and washer, then torqued to 60 inch-pounds. |
