Date:    5-28-2011
Number of Hours:    2.00
Brief Description:    RH Wing Tip Skins
Clecoed and riveted the tip rib W-1213-R, hand hold W-1204G-R, bottom skin W-1204C, aft skin W-1204B-R, and forward skin W-1204A-R (page 17-05, steps 1 through 3).
Riveted aft wing tip rib W-1204F-R and forward wing tip rib W-1204E-R (page 17-05, steps 4 and 5).
Page 17-05 is complete for left and right wing.
Clecoed and rveted left wing tip close out W-1204D-L (page 17-06, step 2). Everything fit fine with no adjustments required. Clecoed and match drilled wing tip trailing edge W-1204H-R, then removed and deburred and cleaned up chips. Riveted wing tip trailing edge to wing. (page 17-06, steps 2 and 3).
Page 17-06 is complete for left and right wing.
SECTION 17 WING SKINS IS COMPLETE
