Date:    6-30-2011
Number of Hours:    2.50
Brief Description:    Began Fuselage Kit Inventory
Began inventory and was able to get through sub kits #1 through #10 plus miscellaneous kit parts. The only thing to inventory is the hardware package.
All parts that were inventoried were fine with no obvious damage or missing parts.
There are a lot of parts in this kit so may reorganize inventoried parts to make them easier to find during the build.
For the Record:
Center Section Assembly SN #0474
UPDATE (08-01-11)
Decided to replace the F-1204 center section instead of trying to make the original one that was misdrilled on 07-05-11. See entry on 08-01-11 for details of new serial numbers.
The official serial numbers in N879DB are:
Center Section Assembly F-1204 - SN #0464
Forward Bulkhead Side Assembly F-1204CL-L - SN #0486
Forward Bulkhead Side Assembly F-1204CL-R - SN #0481
