Date:    12-27-2016
Number of Hours:    2.60
Brief Description:    PAP - G6 - Check For Debris
Removed gascolator drain and strained fuel through a coffee filter. Minor swarf was noticed and looked like very fine flakes of aluminum. Probably stuff left in the fuel lines/tank during construction. Very happy with the minimal amount found.
Drained the remaining fuel from fuel tank (about 2 gallons) and also strained through a coffee filter. A few small dirt-looking particles were captured. Looked more like small pieces of fuel tank sealant. Probably some left in tank from scraping during fuel tank doubler mod.
The gasolcator screen had a very thin layer that easily wiped off with a rag. It looked more like fuel being retained in the screen - no obvious other debris.
Re-installed screen and gascolator and safety-wired.
Removed both carb bowls and strained fuel through a coffee filter. Very minor black material caught. Again, probably small pieces of fuel tank sealant.
SECTION G6 IS COMPLETE
