9-9-2019 |
6.00 |
wiring commences |
Today's aim was to sort out the non-avion earths to the common FOT point, and to add an avionics common ground FOT. Having finalised the switch gear and panel arrangement there was a bit of re-routing of the wires, especially the port ZipTips wires. Did a continuity check on all of the Ziptips wires before connecting to the FOT. Attached the common power bus, which will distribute the power to the main bus, avionics bus and endurance bus, that supply the five banks of circuit breakers. Will also need to add a small 'blade fuse' distribution block for odd extras that dont need to clutter the circuit breaker panel |
