Date:    9-2-2019
Number of Hours:    6.00
Brief Description:    Edge trim and vent/heater panel made
Cut and bent some angle aluminium to fix to the lower edge of the panel to stiffen it and make it look better. Turned out nicely.
decided to tackle the vents for the hot and cold air.. I have one large vent for the cold, and two smaller ones so that I can direct the heat to either side, and hopefully to the rear.
