6-5-2019 |
8.00 |
Baffle work, and 'snorkel' installed |
Drilled 3 holes for cooling vents to the alternator, fule pump and mageneto. Not sure if I need to add one for the P mag, or if I can take a 'T' off the pipe to the fuel pump. Fitted the snorkel, attached to the fuel servo.Took 4 hours to make the connection to the cooling ramp of the baffles. |
