5-1-2019 |
6.00 |
Stainless oil lines fitted, Mixture bracket fitted |
Stainless steel braided hoses arrived, with new fittings replaced all of the pipes that I installed at the weekend. Easier second time around. Getting quicker at making up hoses! Made a bracket for the throttle cable and works well. Mixture bracket arrived from Vans but I hadn't ordered all of the parts that I needed... more waiting for FEDEX Fitted Sniffle valve and Quick change oil drain. Changed the oil filter to a smaller diameter one to stop the obvious impingement present between oil return line and the filter Checking with Aerosport power that the swap is ok |
