Date:    11-30-2019
Number of Hours:    7.00
Brief Description:    configuring the components..
slow, tedious progress to configuring the avionics to tak to each other... had to rxtende the OAT probe cable to reach the panel from the wing, still on its ce=radle. Then had to add a 'ground' between the wing and the fuselage. Added the GSA28 adaptor that makes it work when the servo is disconnected...
ended up checking the entire can bus and fixing a few problems.. all working in the end, but took ages....
