Date:    12-28-2019
Number of Hours:    5.00
Brief Description:    ariel cables, cabin heat cables,
A day of fiddling around finishing off odds and ends
Installed the coax from the ELT to the antenna, using 90 degree BNC connectors. Drilled the firewall and ran the heater control cable through as a 'first fix'. Drilled the new cluster to fit the USB update port to the traffic AT-1 unit. Sanded the canopy frame where I'd trimmed it to accomodate the instruments on the panel, and epoxied/filleted the edges. Filleted the back of the canopy where I'd 'cut and pasted' the rear flange back on. Flox/epoxied a few edges of rough fibrelglass.
Installed the rear ipad mount using an aluminium plate and two P'clamps. power confirmed from the Lightning cable, so thankfully I hadn't cut the cable during the installation, months ago.
