Date:    8-29-2019
Number of Hours:    4.00
Brief Description:    Elevator movement range set
More work on the elevators and control rods after sortingout the errors earlier
Set up the laser levels to measure the elevator movement, then made 'stops' to ensure correct range. Final measurements are 30 degrees up (maximum allowed) and 23 degrees down (allowed range is 20-25 degrees)
