5-27-2019 |
7.00 |
Cowling work and throttle quadrant |
painted the throttle quadrant and installed it... needs some fettling as throttle friction too much. Installed nut plated at the front of the cowling, then added 3 coats of epoxy to the outer skin to seal it. The honeycomb texture of the glass created a strange pattern on the epoxy... will just have to sand it down and then spray with high build primer |
