3-20-2019 |
7.00 |
wiring looms for wings done |
Installed wiring looms for the ZipTips lights on each wing. Played around with the earth system and fitted it. Earth lead from battery, to A Firewall mounted filed of tabs on engine side, with earth direct to starter motor and engine ground. From the Firewall, another earth lead runs back to the front baggage rear wall onto a 48 oin FOT, which will link to a specific avionics FOT. Looks neat, but will need the baggage floor to be modified to allow the passage of the earth wires. Took a while to get all the cable runs straight and neat, without twists. Next task is to connect the rear strobe synch to the wingtip strobe synch. |
