Date:    3-10-2019
Number of Hours:    7.00
Brief Description:    Wiring...
Decided to get to grips with some of the wiring, so that I can fix the floors in ...
Redid some of the conduit prep to make it all look neater. Ran wires for the elevator trim servo, rear LED lights and the Garmin GMU11. Redid the DME coax run, moved the static lines to a better place, and installed a ground wire from the battery to the firewall, where it will connect to 'forest of tabs' through to the firewall and then the starter ground and engine ground.
Ready to fix the floors tomorrow!
