1-21-2019 |
7.00 |
More fibreglass work, rivetted the rear skin fully |
More sanding of the canopy frame, then more filling. Set aside to cure, and I reorganised the workshop in preparation for putting the wings on... this meant taking the tailspring off, and making a mounting frame on castors in order to reduce the overall length. Took HS off and mounted it to one of the engine stands used for the rotisserie so that I can work on it as and when needed. Left the VS in position after rivetting the final sections of the rear skin. Just need to figure out the cabe run to the rear nav/strobe lights. Also had good news from Aerosport about the engine... ist built, and ready for test run! |
