1-16-2019 |
6.00 |
Nearly finished the fairing, and added the lower f |
More sanding, priming, sanding, re-filling, sanding. Fixed back onto the fuselage and looks almst good enough. trimmed the lower fairing strip, drilled and tapped into the longerons and added the rubber seal. Needs some work on the join between the two. |
