1-14-2019 |
5.00 |
More empennage fairing work... |
Fitted it back on, and drilled the holes through into the HS after marking holes with laser pointer. Decided to use Tinnerman washers rather than unsupported countersunk heads. The VS base didnt fit well enough, so I re-did the front section. Its cold, so epoxy taking ages to go off! Did a bit more work on the canopy shell to fill the time... |
