1-13-2019 |
7.00 |
More fairin work |
More sanding and filling, almost there! Nut plates attached to the fin and HS, and fairing attached. A bit more filer for the edges, and some reshaping of the front edge needed. Lower aluminium fairing cut, edged and drilled to fit. Need to tap the holes in the longerons next. |
