12-7-2018 |
3.00 |
Rudder trim mount design and fabrication |
Started to figure out how to make electric rudder trim. Aim is to have balanced springs connected to a trim servo similar to the aileron trim. Similar mods carried out of Tom Dietrich's Husky and it worked well (although his was manually operated) Decided to make a mount bracket to be attached beneath the front seat plate, with 4mm stainless cables passing from beneath the seat, out to the side then following under the rear seat pedal arms to the rear seat rudder pedal mounting bracket. Should keep it out of the way, and discrete. |
