11-14-2018 |
8.00 |
Baggage door work, and pitch servo installed |
After primign the interior sections of the baggage door, started to rivet them all together. Fitted pretty well, but I decided to remove a few rivets from the top skin and insert some shims to improve the fit. Slow, tedious work but worth it in the end. Started to install the Garmin pitch servo so that all prep work in the tail cone is done as its almost time to rivet the turtledeck on! Ive run some conduit down the starboard side for wiring to the elevator trim and the rear light. Hopefully, turtledeck will be done by the weekend. |
