10-12-2018 |
4.00 |
Front skin cutting |
Side rails fully drilled to accept the extra nut plate recuird by the fastback kit. Bolts for the seat support fitted. Then the fron skin... clecoed innplace, and the stiffener for the rear cut contoured to fit, skin marked, then out with the Dremel! Looks good, next step is toback drill through the stiffener into the skin, clecoe, and then finish off the edge. |
