3-4-2020 |
10.00 |
fuel stuff, fairings, rudder pedal stress loading |
Fitted the empennage fairings Tidied up the wiring loom in the rear removed the O2 cylinder from the front baggage Found a fuel leak...tightened up a joint at the SB fuel tank fitting, and it stopped... Drained the SB tank as it didnt match fuel levels in the port side... obviously I goofed up.. Found that the right and left fuel level indicators were switched at the GEA 24... had to take the panel apart to swap pin 6 and 9 in GEA24/424 d-sub. refilled the tank, and set the flight and ground fuel level settings. Both tanks now full.. and I seem to be able to get 68 litres in each tank Took a rudde rpedal off and stress loaded it to 200kg... hopefully enough for the LAA. |
